No map in C++ or QML sample applications
1287
02-16-2017 01:34 AM
RenaudGuezennec
Hi all,
I'm trying to run your C++ or QML  sample application and they stay gray. I'm also seeing some blinking.
I downloaded the SDK, I install it on my laptop (on Ubuntu 16.04) and then I started the script: ArcGISRuntimeSDKQt_CppSamples.sh and ArcGISRuntimeSDKQt_QMLSamples.sh
Both applications have the same trouble. Did I do something wrong ? Did I forget setup steps ?
Regards
Renaud G.
LucasDanzinger
Esri Frequent Contributor
This sounds similar to this thread Sample code
Do you have the OpenGL requirements installed? Qt for Linux/X11 | Qt 5.8
RenaudGuezennec
Yes I did, I will have to try on another computer to see if the issue comes from my hardware.
I have to check about the network.
