Is there a way to ADD a jpeg to an mxd when there is not an existing jpeg being replaced?
1120
02-20-2017 06:44 AM
petegillard
New Contributor III
we have a custom north arrow that is stored as a jpeg. trying to add it to an mxd. I noticed the height/width and xy placement options, but no way to add it to an existing map.?
Pete
DanPatterson_Retired
arcpy.mapping constants Listlayoutelements refers to 'existing' elements and the mapsurroundelement only has read/write properties for some aspects... creating in the void doesn't appear to be one of them
LukeWebb
Occasional Contributor III
You cannot add elements using Arcpy.Mapping
Maybe you could solve the issue the 'other way round', update a template, and then use arcpy to pull in the datasets from the existing mxds.
petegillard
New Contributor III
O.K. Thanks to both for the responses
