How do you join (or dissolve) a line segment to its neighbour that is the shortest?
1739
10
02-20-2017 07:34 AM
by Anonymous User
Not applicable
Hi, what I am trying to do is join/merge/dissolve a line segment (part of one line feature class) to its closest shortest line (within the same feature)
AbdullahAnter
Occasional Contributor III
Do you mean separate lines in one record, or auto matching between two closest lines?
by Anonymous User
Not applicable
auto matching between two lines. Basically imagine there are 3 line segments in a row (10m, 5m & 15m) I want the 5m segment to dissolve into the 10m segment.
DanPatterson_Retired
dissolve and unsplit line offer nothing?  how many features do you have to do and how many times do you have to do this?  seems like a bit of overkill to try to develop a model for this unless it is needed because of some issue with your incoming data source
by Anonymous User
Not applicable
Can't use unsplit line because of licence level. (see above comment which describes what I want to do). I have to do this for around 1000 line segments.
AbdullahAnter
solve it with topology
by Anonymous User
Not applicable
Remind me how that can be done?
AbdullahAnter
see that link:
Geodatabase topology rules and topology error fixes—Help | ArcGIS Desktop
Read Line rules ,
Must Not Have Dangles
wouldn't that just handle dangles and not the case where the shortest segment may be between two other segments as in the case in the example of 10, 5, 15 that Tim used?  Basically I can think of too many exceptions to a rule set, I don't suppose dissolving them then resplitting using positionAlong (ie 50% or something) would be any use.
AbdullahAnter
I am not choose that rule , because the lines have dangles. but the method of solve dangles (Extend)
He can use extend to match closest line.
