Find the percentage of polygon that overlaps other polygon
2772
7
02-22-2017 09:14 AM
LindseyWinn
New Contributor III
Hello! I two polygon layers - one of which I need to find the percentage of how much of those polygons are outside of the much larger polygon (Places shapefile to MSA shapefile). Thank you!
LindseyWinn
New Contributor III
I can get the area of each polygon - I run the insect tool and then calculate area. But then how do I show which ones fall outside of the main polygon and the percentage of each one? So ideally, I want every polygon that falls inside my larger polygon to be labeled as "100%" and all others that fall outside of it to be labeled 50%, 10%, and so on. Does this make sense?
JoeBorgione
Add a field called OriginalArea of double type; calc it to equal the area.  Then perform your geoprocessing.  You'll end up with a new area, which when you divide it by OriginalArea will give your percentage.
LindseyWinn
New Contributor III
Excellent, thank you! I'm almost there. I calculated the original area, then ran the intersect tool, then calculated the new area. Then I created a new field and used the field calculator to computer (OriginalArea/NewArea) * 100 to get the percentage. The polygons that are completely inside are labeled as 100%, but the polygons that are 50%, 10%, etc. inside the polygon have weird numbers (for example, one of the slivers that is inside the polygon is calculated as 1328227643.9 (the new area was calculated as 0.00003). I know it's just a matter of my calculations, but how do I fix that? Thanks!!
DarrenWiens2
MVP Honored Contributor
It should be NewArea/OriginalArea *100.
LindseyWinn
New Contributor III
Ahhhh yes - THANK YOU!
JoeBorgione
And what Darren said.....
lewinn
BruceHarold
See if the Tabulate Intersection tool will give you what you need.
