FeatureLayer.SetDefinition Broken?
1576
6
02-21-2017 06:04 PM
KirkKuykendall
Occasional Contributor III
I would expect the following code to essentially clone the top layer in the map.  It does create a new featurelayer that points to the Uri, but calling SetDefinition has no discernible effect.
private void Test()
    var def = MapView.Active.Map.Layers[0].GetDefinition() as CIMFeatureLayer;
    var conn = def.FeatureTable.DataConnection as CIMStandardDataConnection;
    var folder = conn.WorkspaceConnectionString.Split('=')[1];
    if (conn.WorkspaceFactory != WorkspaceFactory.Shapefile)
        throw new Exception("test only works with shapefile layers");
    var url = Path.Combine(folder, conn.Dataset + ".shp");
    var fLayer = LayerFactory.CreateFeatureLayer(new Uri(url), MapView.Active.Map, 1);
    fLayer.SetName("my layer");
    // name remains "my layer" Setdefinition has no discernible effect
    fLayer.SetDefinition(def);
Tags (1)
KirkKuykendall
Here's a simpler example.  SetDefinition doesn't do anything from what I can tell.
private void Test()
    var fLayer = LayerFactory.CreateLayer(def.FeatureTable.DataConnection,MapView.Active.Map) as FeatureLayer;
    // name remains "my layer" Setdefinition has no discernable effect
CharlesMacleod
Get and Set definition are a transactional pair. That is, you have to "get" a layer's definition, change it, then "set" it (or commit it) back to the repository. Think of it like a record in a database. It has an id and some other identifier information. It cannot be shared. In your code above I would imagine that the layer in
will have had its name changed to "my layer". Ditto for the code sample above.
CharlesMacleod
Actually, I looked closer at your code. In retrospect, it looks like you may be overwriting your change. For
to have been changed you would have needed to have updated its definition before the
set (on flayer). Either way, the key is you have to get a definition, change it, then
set it back.
KirkKuykendall
Thanks for replying Charles.
When I open a .lyrx file in a text editor, I see that it contains a CIMLayerDocument, which has a list of CIMLayers (e.g. CIMFeatureLayer etc.)  When I choose to add data and select a .lyrx file behind the scenes Pro is turning definitions into layers.  I want to be able to do something similar.  Is this functionality exposed by the API?
If not, I think Esri really needs to add another overload to LayerFactory.CreateLayer which accepts a CIMLayer definition.
Otherwise, if there is a bug in SetDefinition, perhaps I could accomplish this once the bug is fixed.
CharlesMacleod
Use LayerFactory.CreateLayer directly with the layer file....or....is that not doing what you want?
https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-MapAuthoring#create-and-add-a-layer-to-the-a...
KirkKuykendall
I think I resolved this by setting the URI of the definition to that of the newly created layer before applying.
Any known ill side-effects from doing this?
def.URI = fLayer.GetDefinition().URI;
fLayer.SetDefinintion(def);
