Add raster to mosaic dataset fails
3853
02-23-2017 12:14 PM
IonutAron
Frontend: ArcGIS 10.4.1 on Windows 10
Backend: ArcSDE 10.4.1 and Oracle 12c on Windows Server 2012 R2
I've created a raster mosaic and added two rasters to it. Then I versioned the Footprints table in order to add a field for the "Year" (so I can use the time slider). All worked fine....
Problem occurs when i try to add more rasters into the mosaic.
If I run the tool from ArcCatalog, I get this error message:
Executing: AddRastersToMosaicDataset MKRF_GIS.Orthophoto_Master "Raster Dataset" \\MyServer\gis\Connections\Administrator\mkrf_gis@default@mkrforcl2.sde\MKRF_GIS.Orthophoto_2006 UPDATE_CELL_SIZES UPDATE_BOUNDARY NO_OVERVIEWS # 0 1500 "PROJCS['NAD_1983_UTM_Zone_10N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-123.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision" # SUBFOLDERS OVERWRITE_DUPLICATES BUILD_PYRAMIDS CALCULATE_STATISTICS BUILD_THUMBNAILS # NO_FORCE_SPATIAL_REFERENCE ESTIMATE_STATISTICS #
Start Time: Wed Feb 22 15:40:31 2017
2017-02-22T15:40:31.658: Loading raster datasets
ERROR 999999: Error executing function.
Cannot create an insert cursor using the mosaic dataset.
Objects in this class cannot be updated outside an edit session [MKRF_GIS.AMD_Orthophoto_Master_CAT]
Failed to execute (AddRastersToMosaicDataset).
Failed at Wed Feb 22 15:40:31 2017 (Elapsed Time: 0.62 seconds)
If i run the tool from ArcMap, inside an edit session, I get this message:
Executing: AddRastersToMosaicDataset MKRF_GIS.Orthophoto_Master "Raster Dataset" \\My Server\gis\Connections\Administrator\mkrf_gis@default@mkrforcl2.sde\MKRF_GIS.Orthophoto_2006 UPDATE_CELL_SIZES UPDATE_BOUNDARY NO_OVERVIEWS # 0 1500 "PROJCS['NAD_1983_UTM_Zone_10N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-123.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision" # SUBFOLDERS OVERWRITE_DUPLICATES BUILD_PYRAMIDS CALCULATE_STATISTICS BUILD_THUMBNAILS # NO_FORCE_SPATIAL_REFERENCE ESTIMATE_STATISTICS #
Start Time: Wed Feb 22 15:57:30 2017
2017-02-22T15:57:30.904: Loading raster datasets
The requested operation is invalid on a closed state [MKRF_GIS.AMD_Orthophoto_Master_CAT]
Failed at Wed Feb 22 15:57:30 2017 (Elapsed Time: 0.57 seconds
Any ideas?
Ionut
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Ionut,
I would unregister the footprint layer as versioned and see if you can then add the rasters.  You can still edit the mosaic dataset when the footprint is not registered as versioned:
Configuring an ArcMap edit session to perform nonversioned edits—ArcGIS Help | ArcGIS Desktop
JakeSkinner
Hi Ionut,
IonutAron
That fixed it.
Thanks so much
