Get MapService on Map Click Event
1661
5
02-23-2017 03:21 AM
PrasadG
hi....
 I have task  when i click on map,  active layer information show on  popup window, it is possible with query task but i have  many map services and activate it dynamically. means whatever feature on map I want to show information when i click on feature without define map or feature service. I want to get feature on map service when click on respective feature then i want to query. is it possible ?.........Thanks
KenBuja
MVP Esteemed Contributor
Take a look at this discussion, which returns the map service information for layers in different services.
Get an IdentifyParameter for an IdentifyTask result
FC_Basson
MVP Regular Contributor
What API version are you working with?
In 3.19 you can easily get the visible layers through the map objects different layer properties e.g.
map.layerIds or map.graphicsLayerIds
Then you can check if the layer is visible, get the URL for the layer and get the layer properties as JSON through a standard request (https://[server]/arcgis/rest/services/[service]/MapServer/[layerID]/?f=pjson)
RobertScheitlin__GISP
Prasad,
  You could use the IdentifyTask for this if you do not want to send a query to each individual layer.
KenBuja
PrasadG
Thanks.... ken your code exactly match my requirement. it is very helpful for me..
KenBuja
If this answered your question, please click the Mark Correct button.
