Help C# Points to Line conversion
1863
02-22-2017 05:43 PM
Cibi_PranavP_S
I am working on a tool to convert point to line using ArcObjects in C#. I can understand the arcpy function but is there an example to show how to convert a point layer into a line feature and save as a new line layer? Any code snippet will help.#PointsToLine
DuncanHornby
MVP Notable Contributor
You could call the existing geo-processing tool, that would be easiest. One way to do this is to be using the IGeoProcessor object and call the tool.
Search the API help there are numerous examples of tools being run using this approach.
KenBuja
MVP Esteemed Contributor
This is a portion of the code I used in a tool that converted points (pPointFLayer) to a line (pLineFLayer)
    Dim pPointFLayer As ESRI.ArcGIS.Carto.IFeatureLayer
    Dim pFCursor As ESRI.ArcGIS.Geodatabase.IFeatureCursor
    Dim pFeature As ESRI.ArcGIS.Geodatabase.IFeature
    Dim pFirstPointShape As ESRI.ArcGIS.Geometry.IGeometry
    Dim pFirstPoint As ESRI.ArcGIS.Geometry.IPoint
    Dim pSecondPointShape As ESRI.ArcGIS.Geometry.IGeometry
    Dim pSecondPoint As ESRI.ArcGIS.Geometry.IPoint
    Dim pLine As ESRI.ArcGIS.Geometry.ILine
    Dim pSegColl As ESRI.ArcGIS.Geometry.ISegmentCollection
    Dim pGeomColl As ESRI.ArcGIS.Geometry.IGeometryCollection
    Dim pPolyline As ESRI.ArcGIS.Geometry.IPolyline
    Dim pIFBuffer As ESRI.ArcGIS.Geodatabase.IFeatureBuffer
    Dim pIFCursor As ESRI.ArcGIS.Geodatabase.IFeatureCursor
      pIFCursor = pLineFLayer.FeatureClass.Insert(True)
      pIFBuffer = pLineFLayer.FeatureClass.CreateFeatureBuffer
      pFCursor = pPointFLayer.Search(Nothing, False)
      pFeature = pFCursor.NextFeature
      Do Until pFeature Is Nothing
        FirstGroupID = pFeature.Value(pFeature.Fields.FindField(cboField.Text))
        pFirstPointShape = pFeature.Shape
        pFirstPoint = pFirstPointShape
        If pFeature Is Nothing Then Exit Do
          pSecondPointShape = pFeature.Shape
          pSecondPoint = pSecondPointShape
          pLine = CreateLn(pFirstPoint, pSecondPoint)
          pSegColl = New ESRI.ArcGIS.Geometry.Path
          pSegColl.AddSegment(pLine)
          pGeomColl = New ESRI.ArcGIS.Geometry.Polyline
          pGeomColl.AddGeometry(pSegColl)
          pPolyline = pGeomColl
          pIFBuffer.Shape = pPolyline
          pIFCursor.InsertFeature(pIFBuffer)
      Loop
    Private Function CreateLn(ByRef pPointFrom As ESRI.ArcGIS.Geometry.IPoint, ByVal pPointTo As ESRI.ArcGIS.Geometry.IPoint) As ESRI.ArcGIS.Geometry.ILine
      CreateLn = New ESRI.ArcGIS.Geometry.Line
      CreateLn.PutCoords(pPointFrom, pPointTo)
    End Function
