How can I use my feature layers from my server with web appbuiler app without uploading my layers to my esri account?
554
02-24-2017 06:59 AM
BarboraBorosova
I just create a web app buid map and feature layer I want to add separately from another server.
MichaelMiller2
Occasional Contributor III
You can add content to a AGOL map via the rest endpoint from your ArcGIS Server. Use Add > Layer from Web, copy and paste the URL and away you go.
JayantaPoddar
MVP Esteemed Contributor
You could opt for Portal for ArcGIS, which is an in-house cloud. All the shared data would be stored in your organization's storage/premises.
About Web AppBuilder for ArcGIS—Portal for ArcGIS (10.5) | ArcGIS Enterprise
Think Location
DerekLaw
Esri Esteemed Contributor
Hi Barbora,
You could just use an "empty" web map as the starting point for your web app, then use the Add Data widget to add your web services.
Hope this helps,
RebeccaStrauch__GISP
If you are using the web AppBuilder developer edition, check out LocalLayerWidget and AccessifizrWidget‌
this and other widgets and related blogs can be found /blogs/myAlaskaGIS/2016/03/09/web-appbuilder-developer-edition-customization-resource-list?sr=search...
