Generate Service Areas tool
408
02-24-2017 07:32 AM
YosefBodovski
Hello, I need to generate service areas for more than 200,000 locations across the US. I am using the GenerateServiceAreas tool through ArcGIS online, but it allows me to run only 1,000 features at a time. I tried to split my master dataset and run smaller portions in a batch mode, but the output file contains only features from the last dataset on the list.  Any ideas? Thanks!
MelindaMorang
Hello, Yosef.  You probably just need to save the output from each chunk separately and then merge them all at the end.
