in_memory png to base64 string
1893
7
02-24-2017 10:39 AM
JasonLevine
Occasional Contributor II
Does anyone know how to convert an in memory png to a base64 string?
My raster is defined as:
png = "in_memory\my_png.png"
I then try to convert it:
import base64
base64_string = str(base64.b64encode(png))
base64_string gets populated as: aW5fbWVtb3J5XG15X3BuZy5wbmc=
Which, when decoded is: in_memory\my_png.png
...not exactly what I had in mind.  Is this even possible do do in a geoprocessing script?
Jason
TomSellsted
MVP Regular Contributor
Jason,
I had done something similar, but was loading an image file from disk.  To encode it I had to read it.  Something like:
with open(driverPhoto, "rb") as imageFile:
    encodedPhoto = base64.b64encode(imageFile.read())
Perhaps you have to do a read as well.
Regards,
Tom
JasonLevine
Tom,
Good idea...however, python doesn't seem to want to open an "in_memory" raster:
Runtime error
  File "<string>", line 1, in <module>
IOError: [Errno 2] No such file or directory: 'in_memory\\my_png.png'
Jason
TomSellsted
Jason,
It should already be open, I was suggesting that you read it.  Could you provide the code you have attempted?
Regards,
Tom
JasonLevine
I'm using arcpy.CopyRaster_management to copy a local tiff into an in memory png:
tiff = r'C:\Temp\my_tif.tif'
png = r'in_memory\my_png.png'
CopyRaster_management(tiff, png, pixel_type='32_BIT_SIGNED', format='PNG')
f = open(png)
TomSellsted
Jason,
Thanks for the code, that gives me some context.  Maybe try:
b64 = base64.b64encode(png.read())
Regards,
Tom
DarrenWiens2
MVP Honored Contributor
I'm surprised that it's possible to save a file in the in_memory workspace ending in '.png', although I see that you can. The file isn't actually .png format, though, it's a geodatabase raster (check the layer properties).
JasonLevine
You're right Darren, I was getting thrown off by the png extension.  It's not actually a png, it's a geodatabase raster.  It looks like you can only store "raster" in the in memory workspace.
