set the on-screen widget position programmatically
3598
12
02-24-2017 11:24 AM
LefterisKoumis
Occasional Contributor III
I use the _setDesktopPosition function used in the OnScreenWidget.js in my custom widget.js to set the position of a panel at start up but it ignores it.
Ideas?
startup: function () {
html.place(this.domNode, jimuConfig.mapId);
html.setStyle(this.domNode, {
left: 100 + 'px',
right: 'auto',
top: 100 + 'px',
// width: (position.width || this.position.width || this._originalBox.w) + 'px',
// height: (position.height || this.position.height || this._originalBox.h) + 'px'
thank you.
RobertScheitlin__GISP
Lefteris,
  When using the launchpad theme you should use:
      startup: function() {
        this.inherited(arguments);
        var position = {
          relativeTo: map,
          left: 277,
          top: 225,
          width: 300,
          height: 420
        this.getPanel().setPosition(position);‍‍‍‍‍‍‍‍
Lefteris,
  Where is the widget coming from (i.e. on screen widget place holder, some widget controller like the header)?
LefterisKoumis
This is a custom on-screen widget. I don't know if it matters since it is not in the  header, but fyi I am using the launchpad theme.
Thank you.
so it is not in the anchor bar controller?
LefterisKoumis
No.
Here is how the GetInfo widget is defined in the config.json:
"widgetOnScreen": {
"widgets": [
"uri": "themes/LaunchpadTheme/widgets/AnchorBarController/Widget",
"position": {
"bottom": 10,
"height": 40,
"relativeTo": "map",
"zIndex": 0
"version": "2.3",
"id": "themes_LaunchpadTheme_widgets_AnchorBarController_Widget_19",
"name": "AnchorBarController"
"uri": "themes/LaunchpadTheme/widgets/Header/Widget",
"position": {
"left": 15,
"top": 17,
"width": 670,
"height": 46,
"relativeTo": "map"
"version": "2.3",
"id": "themes_LaunchpadTheme_widgets_Header_Widget_20",
"name": "Header"
"uri": "widgets/GetInfo/Widget",
"config": "configs/GetInfo/config_GetInfo.json",
"id": "widgets_GetInfo_Widget_36",
"IsController": false,
"name": "GetInfo",
"version": "1.3.1",
"label": "Get Info",
"openAtStart": true
Thank youl.
So if it is an on screen widget then the panels position is controlled by the onScreenWidgetIcon.js getOffPanelWidgetPosition function.
LefterisKoumis
Perhaps in the postCreate function, I could redefine the widget position? After the widget is created, can we redefined the postion?
it have to happen in the onOpen or startup as they occur after the setPosition in the widget lifecycle:
Widget life cycle—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
LefterisKoumis
That bring me back to the original question when I posted this question. The script I used in the startup function did not alter the postion of the widget. What am I missing? Thanks.
Drew
This works for me (see below)
  domStyle.set(this.domNode, "right", "100px")
  domStyle.set(this.domNode, "top", "100px")
Maybe you have a CSS class over writing the style?
