Multiplying Attributes
685
02-24-2017 01:14 PM
GeoffAbma
I would just like to multiply 2 attributes together.
I need some help because I'm apparently doing something wrong.
//First, I am defining an attribute which is linked to the initial shape's area attribute from the imported Shapefile:
attr SHAPE_Area = ""
//Then I am setting the maximum coverage permitted in the zoning by-law:
attr maxCoverage = 0.65
//And I simply want to generate the maximum building footprint area by multiplying these two attributes together, like this:
attr buildingFootprint = maxCoverage * SHAPE_Area
I am just not sure what the correct syntax is to do this.  I am getting this error:
No such function: float *(a:float,b:str)
Unused function:buildingFootprint
Any help would be appreciated.
Cheers!#
LR
Occasional Contributor III
You're defining SHAPE_Area as text. Either define it as float (SHAPE_Area = 0) or cast it as float later (attr buildingFootprint = maxCoverage *float(SHAPE_Area)).
GeoffAbma
Thanks for this.  I finally realized that I was defining it as text instead of float myself late last night.  Made all the difference in the world!
