Hello;
Can anyone tell me how can I create a reference plane that is not necessarily parallel to the surface?
I have an irregular terrain in which I need to build a steel structure.
This structure will consist of a 3mt x 3mt grid of steel columns (~600); all columns have the same length.
There is a min and max distance from the ground that applies to all columns. The top of all columns must be within the same plane.
The plane defined by the top of all columns has a tolerance to N-S slope (Max 7%)
Can anyone suggest how should I tackle this problem using ArcMap and ArcScene? I thought about the following steps:
Does this make any sense??
Thanks in advance for your help
Miguel
