ArcMap 10.5 Crashes on .sdat files
1241
02-26-2017 08:56 PM
MarkChilcott
Occasional Contributor III
Hi Peoples,
Upgraded to ArcGIS 10.5.
Open a project containing a raster .sdat file.  Crash.
Open ArcMap
New blank document
Add .sdat raster
= Crash
Do the same in 10.3.1 = OK.
Anyone else seen this?
Cheers,
Mark
JayantaPoddar
MVP Esteemed Contributor
Does ArcMap crash when adding other raster format data? Does the issue occur with all .sdat format data?
I don't have .sdat data with me to test.
But you may
1. Close all ArcGIS applications, and open a new ArcMap session.
2. Make sure the .sdat file format is enabled for ArcMap to read(Customize > ArcMap Options > Raster > File Formats).
3. Try Resetting your ArcGIS application profile
4. Ensure the video adaptor is up-to-date.
If nothing works out, it would be wise to call Esri Tech Support to resolve the issue.
Think Location
MarkChilcott
Hi Peoples,
esri support reproduced the problem.  Looks like a bug introduced in 10.5.
Cheers,
Mark
JayantaPoddar
Good to know. Thanks!!!
Think Location
