printing issue on external basemap?
3062
8
02-26-2017 11:19 PM
sureshmanickam
If i use external map services as basemap, printing is not working in portal for ArcGIS-4.1.please anyone provide some solution #print option
Tags (1)
JonathanQuinn
Esri Notable Contributor
What error do you get?  If you're using a print service from a federated server, take a look at the logs on that machine.  If that's the case, if you were to remote into the Server machine as the user running the ArcGIS Server Windows service, are you able to reach the Services URL of the service you're trying to print?
sureshmanickam
iam getting below logs msgs from server logs. but i can able to reach map service URL.
SEVERE
Feb 28, 2017, 11:48:51 AM
Error executing tool. Export Web Map Job ID: j28723874e6f147079d2804de376cd297
PFARCGIS/ExportWebMap1.GPServer
SEVERE
Error executing tool. Export Web Map Job ID: j28723874e6f147079d2804de376cd297 : Layer "Satelitte_5223": Unable to connect to map server at https://<servername>/arcgis/rest/services/Satelitte/Satelitte/MapServer. Failed to execute (ExportWebMap). Failed to execute (Export Web Map).
WARNING
Feb 28, 2017, 11:48:50 AM
The server name or address could not be resolved (WinINet Error while using HTTPS security, 12007), URL = https://<servername>/arcgis/rest/services/Satelitte/Satelitte/MapServer?f=json
WARNING
The server name or address could not be resolved (WinINet Error while using HTTPS security, 12007), URL = https://<servername>/arcgis /rest/info?f=json
 thanks
FC_Basson
MVP Regular Contributor
At least you know that according to the error code 12007 the server name is not resolving. (https://support.microsoft.com/en-us/help/193625/info-wininet-error-codes-12001-through-12156)  Can you ping the server?
sureshmanickam
i am able to reach this URL & add this map service in the portal-map and it displays..while printing only it gives this error..
thanks
JonathanQuinn
It sounds like the Server machine can't make outbound requests to external resources.  This could be an outbound proxy issue or something else.  Have you been able to reach the service URL when you remote into the Server machine as the user running the ArcGIS Server Windows service?
sureshmanickam
yes,i can able to reach Service URL from server machine as the user running the ArcGIS Server Windows service.
FC_Basson
Have you tested if it works when you disable the server's firewall?
FC_Basson
I think you're having similar issues as described here: https://community.esri.com/thread/81811  and the advice by KOGuinn-esristaff‌ sounds like it might help.
