Why Gray and Hybrid basemaps count for 2 layers?
1225
03-02-2017 02:11 PM
EdgarCanul
New Contributor III
When I begin my application with Street as basemap layer and two more feature layers, I have 3 layers in total
map.getLayer().size
But when I change the basemap layer to Gray_base or Hybrid:
map.setMapOptions(new MapOptions(MapType.GRAY_BASE));
One more layer is added (4 after the change). If I change again to other basemap not being GRAY_BASE or HYBRID the extra layer is removed (having 3 as initially)
Why this happens? I think it's not an error in my code because even the sample code (the MapOptionsApp example) shows this behavior.
What can I do to avoid this extra layer?
Beforehand thanks a lot.
nita14
Occasional Contributor III
Hi Edgar,
This is because the selected basemap consists of two layers: Base (Background) and Reference (Labels).
You can examine these using basemap item definition.
Hope this clarifies your concern,
Regards,
Adam
nita14
Hi Edgar,
Regards,
Adam
EdgarCanul
New Contributor III
thanks a lot. I'll make provision for the use of these basemaps
