Add raster function to raster data (or project in a smart way)
1169
7
03-03-2017 03:45 PM
KasonBennett
Hello all,
I'm trying to project an image onto a map using SDK 100.0.0. I've been trying to create a json of a raster function to do this projection for each image.
I've gone over this code, and copy/pasted the example function into a JSON file, but I cannot get the example code to read these functions. (failed to read xxx bytes). Any suggestions?
Kason
nita14
Occasional Contributor III
Hi Kason,
As far as I know, ArcGIS Runtime 100.0.0 supports reprojection (not datum transformation) of raster by default. You just need to ensure both map and raster spatial reference's datum are the same and layers should align correctly.
Hope this helps,
Adam
KasonBennett
Hey Adam,
Thanks for your reply. I'm still having trouble getting this working. Do you have a working example?
nita14
You can use for example this code:
        Raster raster = new Raster("pathToRasterFile");
        RasterLayer rasterLayer = new RasterLayer(raster);
        rasterLayer.addDoneLoadingListener(new Runnable(){
            @Override
            public void run() {
                System.out.println(rasterLayer.getSpatialReference().getWkid());
                System.out.println(rasterLayer.getLoadStatus().name());
                System.out.println(rasterLayer.getFullExtent().getCenter().getX());
                System.out.println(rasterLayer.getFullExtent().getCenter().getY());
                mapView.setViewpoint(new Viewpoint(rasterLayer.getFullExtent().getCenter(), 3000));
        map.getOperationalLayers().add(rasterLayer);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Also, please be aware that raster datum transformation is also supported at 100.0.0. Sorry for my previous misleading information.
Kind regards,
Adam
KasonBennett
Hello Adam.
Do you have an example of how to do the datum transform? According to the documentation, it's done through loading in a  raster function from a .json file, but I cannot get this to work.
Kason
nita14
Kason,
Could you post your code along with the input raster datasets? That would be a lot easier to examine the issue.
Regards,
Adam
KasonBennett
Adam,
I'm trying to load a raster function. (I think this is how to do the transformations. Is this correct?) I cannot get it to load the json file.
I'm currently just trying to get the example working. (see this) There's no other code or datasets associated with the below code snippet right now, because I cannot get past this point.
testfile.java
public static void testRender()
 RasterFunction rf = new RasterFunction("$PATH_TO_JSON/test.json");
test.json
 "raster_function":{"type":"Geometric_function"},
 "raster_function_arguments":
  "raster_transform":{"raster_transform":"Raster Transform JSON object","type":"Raster_function_variable"},
  "z_offset":{"double":0,"type":"Raster_function_variable"},
  "z_factor":{"double":1,"type":"Raster_function_variable"},
  "raster":{"is_raster":true,"name":"raster","type":"Raster_function_variable"},
  "type":"Raster_function_arguments"
 "type":"Raster_function_template"
Kason
nita14
Hi Kason,
This must be an internal issue in ArcGIS Runtime 100.0.0. If you are current on support, you may want to report an incident.
Regards,
Adam
