Code 500 A JSON Array text must start with '['...
1896
03-08-2017 05:10 AM
TL2
Occasional Contributor III
I get this error and am not sure why...
I am able to sign in to my portal, download surveys.  When I try to submit I get this error.
Any advice?
JTedrick-esristaff
ShobanaSuresh
Hi Tucker,
To fix this issue, please modify below code in Survey123 App XForms/XFormFeatureService.qml file
var formData = {
            "edits": encodeURIComponent(JSON.stringify(edits)),
            "rollbackOnFailure": true,
            "useGlobalIds": useGlobalIds
to
var formData = {
            "edits": JSON.stringify(edits),
Shobana
TL2
After further investigation I have determined that Cloud Make using the AppStudio 1.3.46 is breaking my apps.
Any app that was Built with the 1.3.46 version a week or so ago works fine, any app recently Made with AppStudio 1.3.46 will break the EXACT same app.
I would guess that since the AppStudio upgrade for the new version is has broken the AppStudio 1.3.46 Make.
 I would guess that I need to upgrade to the new version of AppStudio, it would appear that AppStudio 1.3.46 is NOT COMPATIBLE with the new Cloud Make!
JamesTedrick
Esri Esteemed Contributor
Hi Tucker,
Yes, there is a change between 1.3 and 1.4 in how URL encoding is handled (we previously had a workaround implemented in Survey123) - SSuresh-esristaff‌ or elvin‌, could you provide guidance on if it's easy to adjust the workaround?
TL2
I just upgraded to 1.4.18 and received the same results.
ShobanaSuresh
Hi Tucker,
var formData = {
to
var formData = {
Shobana
