Will GME 0-7-4 work with ArcMap 10.5?
3316
5
03-08-2017 12:28 PM
CharlesBailey3
Occasional Contributor II
Have installed R full package, trying to install GME 0_7_4 gives the attached error. It actually installed the first time but didn't have a connection to R. Now it won't install and I have a suspicion it's because I'm running 10.5, but why did it install before? Does anyone have any insight on this?
by Anonymous User
Not applicable
I am also wondering the same thing.... we want to update ArcGIS from 10.3 to 10.5, however we are unsure if GME will still be compatible.
DanPatterson_Retired
No... I had a student call me from a boat off the coast of Alaska that was having issues with getting it to work... Fortunately someone on board had 10.3 so they were good to go.  I suspect the project has been abandoned/shelved since there has been no update since the 10.3 version.  Lesson... next time you get on a boat, make sure you have your prof's text number
by Anonymous User
Not applicable
Wow, your student dodged one there, glad it all worked out Dan. Would you know about any scripts in Python or R that are floating around where I could run the Step Selection Function (SSF) without the need of GME + ArcMap? Or even how the SSF was written so I could replicate it in pure Python or R.
Also, do you know why GME is not compatible with 10.5? I am curious.
to all the above... don't know, but you have the algorithm rolling it out in either would probably be easy.  I find a lot of the GME stuff are common algorithms with a bio-like name flung on.  As for the last question, I haven't had the time to see the exact reason for the problem.  The 'fix' is somehow tied to the non-python/R level since neither has substantially changed (it isn't a python 3.x issue for sure)
by Anonymous User
Not applicable
I ended up figuring it all out using R. I imported my GPS data and converted the date/time attributes to POSIXct / POSIXt data types. Using the ltraj funtion from the 'adehabitatLT' package I created a trajectory object which calculated the observed distances and turn angles. Next I used the rdSteps function from the 'hab' package to calculate a random step distribution, creating my predicted points from the generated empirical distribution. Finally I used the 'sp' package to create the step lines from each observed point to predicted point and exported all my data into shapefile formats. What a ride!
