how to convert .mxd file to shape file ?
17268
03-13-2017 09:25 PM
ArpitSingh
I have created an Arc map document as .mxd file now i want to use that mxd file as shape file in tableau software. How can i proceed with it.
JayantaPoddar
MVP Esteemed Contributor
One can not convert the MXD as a shapefile.
You can export the vector layers present in an MXD as shapefiles using ArcMap only, since MXD files can be opened exclusively in ArcMap.
How To: Export a layer to a shapefile in ArcMap
Think Location
