Python Kivy DLL load failed on Using ArcGIS ArcPy
1201
03-16-2017 08:45 AM
BehrouzHosseini
I am running Kivy and Python properly when it is only Kivy as
import kivy
kivy.require('1.0.6')
from kivy.app import App
from kivy.uix.label import Label‍‍‍‍‍
but when I add ArcGIS Python library called ArcPy like below
import arcpy
import kivy
I am getting following error:
Message File Name Line Position
Traceback
5
C:\Python27\ArcGIS10.4\lib\site-packages\kivy\app.py 327
C:\Python27\ArcGIS10.4\lib\site-packages\kivy\uix\widget.py 219
C:\Python27\ArcGIS10.4\lib\site-packages\kivy\graphics__init__.py 89
init kivy.graphics.instructions (kivy\graphics\instructions.c:14640) kivy\graphics\vbo.pxd 7
init kivy.graphics.vbo (kivy\graphics\vbo.c:5482) kivy\graphics\compiler.pxd 1
init kivy.graphics.compiler (kivy\graphics\compiler.c:2983) kivy\graphics\shader.pxd 5
init kivy.graphics.shader (kivy\graphics\shader.c:11990) kivy\graphics\texture.pxd 3
init kivy.graphics.texture (kivy\graphics\texture.c:31800) kivy\graphics\fbo.pxd 5
init kivy.graphics.fbo (kivy\graphics\fbo.c:7683) kivy\graphics\fbo.pyx 84 ImportError: DLL load failed: The specified procedure could not be found.
can you please let me know why this is happening and how I can fix it?
Tags (1)
AlexanderBrown5
Occasional Contributor II
Bengi,
Is this your actual code:
import arcpyimport kivy kivy.require('1.0.6')  from kivy.app import Appfrom kivy.uix.label import Label
Separate your imports to additional lines:
import arcpy
~Alex
BehrouzHosseini
Thanks Alex but this is generating error on line two
Invalid Syntax
ShaunWalbridge
How did you install kivy? It looks like it didn't install correctly, and is missing the necessary C-extensions (here, Cython based) in order to run.
