Hello everyone,
I am getting the following error when clicking on login on the deployment server, when I open the web application from my desktop in IE or Google Chrome. It works fine if I open the web application directly on the server. I assume that it is a permissions issue.
Failed to load resource: the server responded with a status of 404 (Not Found)
main.js?wab_dv=2.2:173 jimu.js init...
http://[server]/[application]/widgets/WASDTools/manifest.json?wab_dv=2.2 Failed to load resource: the server responded with a status of 404 (Not Found)
ConfigLoader.js?wab_dv=2.2:833 Widget is removed because it is not loaded successfully. widgets/WASDTools/Widget
(anonymous) @ ConfigLoader.js?wab_dv=2.2:833
ConfigManager.js?wab_dv=2.2:127 Lo
