Workflow Manager Unable to Change to Portal User Store
1093
03-17-2017 11:35 AM
DanielJohns
I recently upgraded to 10.4.1 and switched over to Portal for ArcGIS. Our ArcGIS Server is federated with the Portal and users are able to take advantage of Single Sign-On through the browser. Now I'm wanted to move from the Traditional User Store to the Portal User Store.
Initially through the Workflow Manager Administrator when I switched it would show the page for ArcGIS Online (to sign-in). I then added my Portal through the ArcGIS Administrator with no warnings or errors. Now when I go to change from Traditional to Portal, it toggles back to Traditional as soon as I click Portal.
I checked the ArcGIS Connection software, it will shows as connected, but it appears to timeout then shows that's it's "Not currently signed in."
I ran the connection test here are the results:
Proxy Server Test - Passed
No proxy server.
Download Speed Test - Failed
Test site unreachable.
Network Latency Test - Undetermined
Reason Unknown.
Network Route Test - Failed
Reason Unknown.
Does anyone know how to resolve this issue?
Thank you,
Daniel
by Anonymous User
Not applicable
Hi Daniel,
Have you been able to resolve your issue? This is likely something to look at with tech support.
Cheers,
Michael
