How to not display NULL Values in a string label
7983
5
03-20-2017 09:16 AM
KevinWyckoff2
I have a feature class that I want to label based on three fields. It would be great if the first two fields always displayed, and the third only displayed when it isn't null. I have added all the field to a label no problem like this:
Is it possible to eliminate the word NULL in three of the five examples above?
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
You could use Using label classes to label features from the same layer differently—Help | ArcGIS for Desktop .
Create two classes and define SQL Query to identify the subset of the features you want to label in each class.
1. [Field3] IS NULL
2. [Field3] IS NOT NULL
Label Expression for Class 1
[Field1] + " " + [Field2]
Label Expression for Class 2
[Field1] + " " + [Field2] + " " + [Field3]
Think Location
JoshuaBixby
In addition to using label classes, you can define a FindLabel function (make sure to check 'Advanced'):
Expression:
def FindLabel( [Field1], [Field2], [Field3] ):
    return " ".join(str(field) for field in ( [Field1], [Field2], [Field3] ) if field)
Parser:
Python
NinaRihn
Occasional Contributor III
you could add this vb expression:
Function FindLabel ([field 1], [field 2], [field 3])
If [field 3] <> " " then
    FindLabel = [field 1] & " " & [field 2] & " " & [field 3]
else
end if
End Function
this works for me even with Null values
AbdullahAnter
If you have Null values in your field , it is automatically doesn't appear in label.
Just use simple expression: parser VBScript >
[Field1] & [Field2] &[Field3]
NinaRihn
that is true, however the vb expression comes in handy if you would like to add characters or spaces between each value, like this:
    FindLabel = [field 1] & "-" & [field 2] & "-" & [field 3]
else
end if
End Function
then the last dash doesn't show up if the last value is null
