Create a custom event
1276
03-21-2017 02:00 AM
CollinKleiboer
New Contributor III
I want to create a custom event. What's the best way to do that?
Using the Pro SDK classes (like CompositePresentationEvent) or create a 'regular' .NET event?
If it's the best way to use the Pro SDK classes, could you provide me an example?
Thanks.
Kind regards,
Collin Kleiboer
GisSense BV
CollinKleiboer
New Contributor III
I found it (thanks to the IlSpy disassembler!), see files below as an example of an event and eventarg class.
Event-class
public class GetJsonSelectionFinishedEvent : CompositePresentationEvent<GetJsonSelectionFinishedEventArgs>
   public static SubscriptionToken Subscribe(Action<GetJsonSelectionFinishedEventArgs> action, bool    keepSubscriberAlive = false)
      return FrameworkApplication.EventAggregator.GetEvent<GetJsonSelectionFinishedEvent>().Register(action,       keepSubscriberAlive);
   public static void Unsubscribe(Action<GetJsonSelectionFinishedEventArgs> action)
      FrameworkApplication.EventAggregator.GetEvent<GetJsonSelectionFinishedEvent>().Unregister(action);
   public static void Unsubscribe(SubscriptionToken token)
      FrameworkApplication.EventAggregator.GetEvent<GetJsonSelectionFinishedEvent>().Unregister(token);
   internal static void Publish(GetJsonSelectionFinishedEventArgs activeMapViewEventArgs)
      FrameworkApplication.EventAggregator.GetEvent<GetJsonSelectionFinishedEvent>().Broadcast(activeMapViewEventArgs);
EventArg-class
public class GetJsonSelectionFinishedEventArgs : System.EventArgs
   public BasicFeatureLayer BasicFL
      get;
      private set;
   public GetJsonSelectionFinishedEventArgs(BasicFeatureLayer bfl)
      this.BasicFL = bfl;
And then you can use it just like the other available events.
Collin.
CharlesMacleod
Nice job Collin.
