chart size PDF (A3)
1471
03-22-2017 03:11 AM
francescarusso
New Contributor III
Dear all,
does anyone know if it is possible to save the .mxd map into PDF but with an A3 size?
Of course I know how to export the map as PDF but I was wondering whether it is possible to save it in a larger size. and if so, how it is possible.
I have arcMap 10.2.2
Thanks a lot,
F.
JayantaPoddar
MVP Esteemed Contributor
Check if this solution works for you
Printing at defined scale and paper size from ArcMap?
You need to change the page and print setting as desired > Go to Layout View > Export Map (PDF Format).
Think Location
JayantaPoddar
Think Location
francescarusso
New Contributor III
thanks a lot for your prompt reply. It seems it works.
Cheers,
F.
