Failed to execute (InterpolateFromPointCloud)
1772
03-23-2017 08:28 AM
KenZiegler
I am using ArcGIS Pro 1.4.1.
I have tried using the Drone to Ortho Mapping function in ArcGIS Pro several times.  After going through the set up and creating the image collection I attempt to create a DEM from the Image Collection.  The Point Clouds are generated and then when the program attempts to generate the DEM I get a 999999 error. Here is a copy of the log:
Queued...
Generating Point Cloud (phase 1)...
Start Time: Thursday, March 23, 2017 7:24:46 AM
Succeeded at Thursday, March 23, 2017 8:20:22 AM (Elapsed Time: 55 minutes 36 seconds)
Generating Point Cloud (phase 2)...
Start Time: Thursday, March 23, 2017 8:20:25 AM
Distributing operation across 4 parallel instances.
Succeeded at Thursday, March 23, 2017 8:22:28 AM (Elapsed Time: 2 minutes 3 seconds)
Generating Digital Elevation Model...
WARNING 000725: Output Raster: Dataset C:\Users\envkrz\Documents\ArcGIS\Projects\Pix4dLALF\OrthoMapping\LALF_N.eomw\Products\DEMs\LALF_N_dsm.crf already exists.
Start Time: Thursday, March 23, 2017 8:22:34 AM
ERROR 999999: Error executing function.
Failed to execute (InterpolateFromPointCloud).
Failed at Thursday, March 23, 2017 8:22:35 AM (Elapsed Time: 0.68 seconds)
Any ideas?
Ken Ziegler
AlexChristofides2
Strange, as I'm getting same error using same version of ArcGIS Pro, though have not generated a DEM or DTM before - just wondered what settings you were using? It generated the ortho fine prior to attempting to generate, first two steps completed successfully, same as yours.
    Start Time: 24 March 2017 09:44:02
    The parameter is incorrect.
    Failed at 24 March 2017 09:44:05 (Elapsed Time: 2.88 seconds)
KenZiegler
I have attached screenshots of the options I used the last time I ran the DEMs creation Wizard.  The only thing that is different is when the Wizard opens and I navigate to the Point Cloud Settings (Dem1.jpg),   originally Point Ground Spacing had an entry that appeared to be a dot, not a period but a larger dot.  I am rerunning now and changed it to a 1. Have to wait to see what happens.
Ken
TimB
New Contributor III
Has anyone had this issue and been able to resolve it?  I get this error on any dataset I run (esri sample datasets, pix4d sample datasets, my own datasets).  I get this error everytime I try to generate a dsm or dtm and have tried changing multiple settings but still get the same error.
