Webgisdr restore Fail
2245
5
03-22-2017 01:23 PM
EvertonParaguassú_da_Silva
I'm using Webgisdr to do restore from my Portal. Webgisdr is giving problem in Datastore restore. My environment is ArcGIS Enterprise 10.5 - Portal, Gis Server, DataStore. Linux Operating System. Help, please!
PaulDavidson1
Occasional Contributor III
Everton, you need to provide more information for anyone to help you.
Just saying "Webgisdr is giving problem " doesn't give anyone enough information to provide much help.
Hee are some guidelines to tell the community so they can perhaps help you:
  • What Linux version?   Free disk space, RAM, etc... can be helpful (and you might discover an issue there)
  • What is your configuration?  How many servers are involved? Is the Backup on the same server or on a share?
  • What is happening? Where is the process failing?
  • What are the error messages you are receiving?  If none, make that clear.
  • Any log files?
  • Do you have any screen captures of messages?
  • Etc...
The more information you can provide, the better someone can help you.
Good luck!
What Linux version?
RedHat Linux 6.8
5GB de RAM
13GB free in one only partition
All servers installed on a single machine
A fault message appears in the restore dastore
Any log files?
Logs in attachment
JonathanQuinn
Esri Notable Contributor
Was the ArcGIS Data Store validating prior to running the restore?  The error is pretty specific in stating that no connection could be made to the Data Store.  Do you have both the relational and tile cache data store configured?
Thanks for answering,
Yes, the datastore has been validated and is working properly. The datastore is only configured in relational mode.
I noticed that the hostname in the log is in the uppercase (https://SUPORTE03VMLNX.IMG.LOCAL:2443 ). Would that be a problem for WEBGISDR, because the only one that failed was what was in uppercase.
JonathanQuinn
No, casing shouldn't matter.  All that really matters is that the machine is reachable and the Data Store service is running.  Can you take a backup of Data Store and then restore it manually?  That's really what the DR tool is doing, it just bundles up Portal and Server.
