Esri ArcGIS extent finished rendering/downloading tiles notification
601
03-23-2017 03:13 AM
chiragshah4
I need notification when full map render or downloaded so i will export the screenshot. Right now my screenshot taken before map rendering completed that why wrong screenshot display. I android there is one Listener addDrawStatusChangedListener . Any equivalent in ios 100 sdk.
DavidLednik
Occasional Contributor II
Hi!
All 100.0 releases of the API have drawStatus which indicates when the map finished drawing. So until all the tiles are downloaded and rendered, status will be inProgress. Once done it will indicate Completed status.
You can add an observer for that property. And once it's completed you can export the image with
mapView.exportImage
mapView.addObserver(self, forKeyPath: "drawStatus", options: .new, context: &myContext)
regards,
David
GagandeepSingh
To add to David Lednik‌'s answer. We have a sample - Display drawing status - you can refer. And when using KVOs don't forget to remove the observer, when you are done. Otherwise, it can cause problems later.
