i cant find the collector in the mobile application
654
03-25-2017 02:44 AM
AlaKokaly1
i did add the collector from the app integration, and did add a map.
but when i open the workforce application on my mobile i cant find the collector to start it.
Kylie
by Esri Regular Contributor
Hi Ala -- Exactly how you will access the integrated map depends on the device you are using Workforce on: is it Android or iOS, and a tablet or a phone? There will be an option to "Collect at assignment" when you are viewing an assignment.
Take a look at Complete your first assignment—Workforce for ArcGIS | ArcGIS (that's the Android phone topic, but you can change to a different device at the top of it). The steps there talk about using Navigator through "Navigate to Assignment." You'll find "Collect at assignment" and "Survey at assignment" in the same menu, assuming you are using a project with the integration set up and also that you have Collector or Survey123 already installed on your device.
Esri Education Team
