Story Map Data Point Not Appearing Weird
725
03-24-2017 07:24 AM
CharlesEvans1
I have eight data points right now on my story map
https://www.arcgis.com/apps/MapTour/index.html?appid=f13973516ebe4ed4ab2d9085d03a8a66
I have the same map from the app on my own server
http://www.ctevans.net/Slatington/Churches/index.html
but the first data point does not appear there.  Very strange. Any ideas appreciated.
OwenGeo
Esri Notable Contributor
Hi Charles,
OK, sorry that wasn't the issue. The story at the first link seems to no longer be available. I was going to try to check your self-hosted app was pointing to the same appid and/or if both apps were using the same webmap.
If you are still seeing a difference between the two apps I suggest that you contact Esri Support at this point and they should be able to help you troubleshoot further.
Owen
Owen Evans
OwenGeo
Hi Charles,
Can you check in Organize whether you have the point hidden or the "Use the first point as introduction" option turned on?
Owen
Owen Evans
CharlesEvans1
I don't have any "organize the tour" window like this.
CharlesEvans1
Found the organize window but it makes no difference.
OwenGeo
Hi Charles,
Owen
Owen Evans
