Ortho Mapping - errors when creating workspace
8271
29
03-24-2017 09:52 PM
by Anonymous User
Not applicable
Hi all.
Am having my first play with the 'Ortho Mapping' within ArcGIS Pro 1.4. I have some UAV photos captured using a Phantom 4.
I clicked new workspace, entered a name etc, then selected the folder where the photos were located. It successfully detected the geolocation data within the imagery and the spatial reference. I didn't change any parameters, just left everything as default, then I clicked next. It began to create the workspace and a log page appears.
However, here something goes wrong - it begins to spit out errors, looks like they are repeated once for each photo. I have pasted below the error messages. I'd be interested to know if anyone else has experienced this or knows what is happening here and how to fix whatever's going wrong.
Cheers,
-Paul
Queued...
Building image collection...
Start Time: Saturday, 25 March 2017 5:31:24 PM
2017-03-25T17:31:28.826: Loading raster datasets
2017-03-25T17:31:28.972: Completed crawling 573 data source items. Added 573 mosaic dataset items.
2017-03-25T17:31:28.978: Synchronizing crawled data source items
2017-03-25T17:31:29.021: Synchronizing items associated with raster type instance 'UAV/UAS' [ID: 1].
2017-03-25T17:31:29.043: Distributing mosaic dataset operation across 2 parallel instances on the specified host: [LAPTOP-8A254KAB].
2017-03-25T17:31:38.992: Error: 8004206c: Failures reported while processing specified command item. [1]
2017-03-25T17:31:39.002: Error: 80042019: Chained Error ID: 0X80042019
2017-03-25T17:31:39.010: Error: 80042019: Could not build mosaic dataset item. [ID: 1, URI: 'C:\Oskat\photos\DJI_0397.JPG']
2017-03-25T17:31:39.019: Error: 8004103f: Creation of frame camera model failed.
2017-03-25T17:31:39.039: Error: 8004206c: Failures reported while processing specified command item. [2]
2017-03-25T17:31:39.050: Error: 80042019: Chained Error ID: 0X80042019
2017-03-25T17:31:39.059: Error: 80042019: Could not build mosaic dataset item. [ID: 2, URI: 'C:\Oskat\photos\DJI_0398.JPG']
2017-03-25T17:31:39.067: Error: 8004103f: Creation of frame camera model failed.
etc, etc until the end:
2017-03-25T17:33:24.335: Error: 8004206c: Failures reported while processing specified command item. [200]
2017-03-25T17:33:24.345: Error: 80042019: Chained Error ID: 0X80042019
2017-03-25T17:33:24.357: Error: 80042019: Could not build mosaic dataset item. [ID: 200, URI: 'C:\Oskat\photos\DJI_0596.JPG']
2017-03-25T17:33:24.363: Error: 8004103f: Creation of frame camera model failed.
2017-03-25T17:33:24.558: Error: 8004205e: 573 mosaic dataset items could not be built.
2017-03-25T17:33:24.706: Removing invalid mosaic dataset items
2017-03-25T17:33:24.999: Removing unreferenced raster type and overview instances
2017-03-25T17:33:25.011: Removed 573 mosaic dataset items and 1 unreferenced raster type instances.
2017-03-25T17:33:25.270: Removing broken mosaic dataset items.
2017-03-25T17:33:25.499: Removed 0 mosaic dataset items and 0 unreferenced raster type instances.
2017-03-25T17:33:25.685: Completed synchronization: 573 items selected, 0 items synchronized.
ERROR 999999: Error executing function.
Failed to execute (AddRastersToMosaicDataset).
Failed at Saturday, 25 March 2017 5:33:30 PM (Elapsed Time: 2 minutes 5 seconds)
DanPatterson_Retired
by Anonymous User
Not applicable
Thanks Dan.
Seems like it's a more complex than I thought    (i.e. not a straight forward process like drone2map).
I'll have to put it aside for another day to try and work through.
Cheers,
-Paul
NaomiBegg2
Occasional Contributor III
Hi Paul Haakma‌
Did you manage to find a solution?
I am trying to run some photographs taken using a DJI Phantom 4 Pro but I am receiving two errors for each photo
I can't see what specific settings require changing within the New Ortho Mapping Workspace as this is auto filled.
by Anonymous User
Not applicable
HI Naomi,
No I never did - to be honest I have never gone back and tried again (was only ever playing with it to see what it could do).
I had mentally parked it up as something to test again when Pro 2.0 comes out.
If you ever manage to get it going, please do post here.
Cheers,
-Paul
NaomiBegg2
Hi Paul
I've just downloaded Pro 2.0 and given it another run.
This still hasn't been successful but it has provided another line of error code which is helpful.
I now receive the following errors:
   Error: 80004005: Creation of frame camera model failed.
   Error: 80004005: The altitude is too low at -125.378768 meter.
I'm not sure if it is failing to convert the correct height as I definitely haven't flown the drone at -100m!
I thought at first that maybe 125m is the minimum height required, but this number slightly changes for each photo.
MingzhenChen
Might I have the Camera information (Maker and Model)?
by Anonymous User
Not applicable
Hi Mingzhen
The images were taken using a DJI Phantom 4 Pro. This link should give you the details I think:
DJI Phantom 4 Pro – Specs, FAQ, Tutorials and Downloads
Here's a copy/paste of some of the info from that page, hope that's enough info??
Sensor1’’ CMOS
Effective pixels: 20M
LensFOV 84° 8.8 mm/24 mm (35 mm format equivalent) f/2.8 - f/11 auto focus at 1 m - ∞
ISO RangeVideo:
100 - 3200 (Auto)
100 - 6400 (Manual)
Photo:
100 - 3200 (Auto)
100- 12800 (Manual)
Mechanical Shutter Speed8 - 1/2000 s
Electronic Shutter Speed8 - 1/8000 s
Image Size3:2 Aspect Ratio: 5472 × 3648
4:3 Aspect Ratio: 4864 × 3648
16:9 Aspect Ratio: 5472 × 3078
MingzhenChen
Hi Paul,
Thank you so much.
Are the images oblique? Pro is unable to handle oblique images now.
Best regards,
Mingzhen
by Anonymous User
Not applicable
No they aren't. Although even if they were, how would that cause the intial workspace build to fail? I would have thought it would fail later on when it was trying to stitch them together?
