How to download all feature layers without selecting area through IOS SDK.
2728
28
03-27-2017 07:10 AM
KamalMittal
New Contributor III
I want to generate a geodatabase which contain all feature layers data so that I can use that database when there is no internet connection but I do not want to give an option to user to select area of interest.  All feature layer data should be  download automatically in background.
Kamal
Tags (1)
Nicholas-Furness
Hi Kamal.
For each layer you specify in the AGSGenerateGeodatabaseParameters object that you pass to generateJobWithParameters(), you can specify an AGSGenerateLayerOption object. That object has a useGeometry property that you can set to false.
KamalMittal
New Contributor III
Below is the code which I am using to download feature layer. Right now I am getting exception "
Geometry cannot be null in generate geodatabase parameters.
". Actually I want to download all feature layer data automatically in background without user selecting area.
private let FEATURE_SERVICE_URL = NSURL(string: "https://services7.arcgis.com/JRY73mi2cJ1KeR7T/arcgis/rest/services/NewYorkHospitalLayer/FeatureServe...")!
    private var syncTask:AGSGeodatabaseSyncTask!
    private var generateJob:AGSGenerateGeodatabaseJob!
    private var generatedGeodatabase:AGSGeodatabase!
    override func viewDidLoad() {
        super.viewDidLoad()
        self.map = AGSMap(basemap: AGSBasemap.streetsBasemap())
        self.syncTask = AGSGeodatabaseSyncTask(URL: self.FEATURE_SERVICE_URL)
        self.addFeatureLayers()
        self.mapView.map = self.map
        self.generateGeodatabase()
    func addFeatureLayers() {
        self.syncTask.loadWithCompletion { [weak self] (error) -> Void in
            if let error = error {
                print("Could not load feature service \(error)")
            } else {
                guard let weakSelf = self else {
                    return
                for (index, layerInfo) in weakSelf.syncTask.featureServiceInfo!.layerInfos.enumerate().reverse() {
                    //For each layer in the serice, add a layer to the map
                    let layerURL = weakSelf.FEATURE_SERVICE_URL.URLByAppendingPathComponent(String(index))
                    let featureTable = AGSServiceFeatureTable(URL:layerURL!)
                    let featureLayer = AGSFeatureLayer(featureTable: featureTable)
                    featureLayer.name = layerInfo.name
                    featureLayer.opacity = 0.65
                    weakSelf.map.operationalLayers.addObject(featureLayer)
func generateGeodatabase() {
        //create AGSGenerateLayerOption objects with selected layerIds
        var layerOptions = [AGSGenerateLayerOption]()
            let layerOption = AGSGenerateLayerOption(layerID: 0)
            layerOption.useGeometry = false
            layerOptions.append(layerOption)
        //parameters
        let params = AGSGenerateGeodatabaseParameters()
        params.layerOptions = layerOptions
        params.returnAttachments = true
        params.attachmentSyncDirection = .Bidirectional
        //name for the geodatabase
        let dateFormatter = NSDateFormatter()
        dateFormatter.dateFormat = "yyyy-MM-dd'T'HH:mm:ssZ"
        let path = NSSearchPathForDirectoriesInDomains(.DocumentDirectory, .UserDomainMask, true)[0]
        let fullPath = "\(path)/\(dateFormatter.stringFromDate(NSDate())).geodatabase"
        //create a generate job from the sync task
        self.generateJob = self.syncTask.generateJobWithParameters(params, downloadFileURL: NSURL(string: fullPath)!)
        //start the job
        self.generateJob.startWithStatusHandler({ (status: AGSJobStatus) -> Void in
            SVProgressHUD.showWithStatus(status.statusString(), maskType: .Gradient)
        }) { [weak self] (object: AnyObject?, error: NSError?) -> Void in
                SVProgressHUD.showErrorWithStatus(error.localizedDescription)
            else {
                SVProgressHUD.dismiss()
               Print("Database generated successfully")
Nicholas-Furness
Hey Kamal,
Could you be a little more specific about what error you're getting?
KamalMittal
New Contributor III
Hi Nicholas,
I have updated my above code and I am getting below exception:
"Geometry cannot be null in generate geodatabase parameters."
YueWu1
by Esri Regular Contributor
Hi Kamal Mittal,
Maybe you can try this:
1. Based on our REST API, the Create Replica expects you to have geometry for sure:
ArcGIS REST API - Create Replica
  • Envelope simple syntax: geometryType=esriGeometryEnvelope&geometry=<xmin>,<ymin>,<xmax>,<ymax>
2. Then we compare Runtime iOS SDK how to get Envelope. Then we will found this Class: ArcGIS Runtime SDK for iOS: AGSEnvelope Class Reference
3. Then we check generate Geodatabase Class, we saw this property: generateGeodatabaseExtent property
4. The rest we need to do is how to pass the AGSMapView's AGSEnvelope as a parameter to generateGeodatabaseExtent.
5. In AGSMapView Class Reference there is a  visibleArea property. it is a AGSPolygon type, if you check this class, you will find there is a property called AGSEnvelope property in AGSPolygon
6. So technically you can use this line of code to assign the mapview extent as generate Geodatabase Extent:
generateGeodatabaseExtent = self.mapview.visibleArea.extent‍
http://resources.arcgis.com/en/help/arcgis-rest-api/#/Create_Replica/02r3000000rp000000/<strong></st...
Hope this can help.
Nathan
Nicholas-Furness
Thanks for the additional info, Yue Wu.
Kamal Mittal To clarify, even though you need to provide a geometry to the AGSGenerateGeodatabaseParameters.extent property, setting the layer options as you did should override that and return all data.
KamalMittal
New Contributor III
Thanks Nicholas. Now I am able to get all layer data. There is one question for you. Can I include multiple feature layer url's data into same geodatabase and can use it when offline?.
Kamal
KamalMittal
New Contributor III
Thanks Yue Wu for good explanation
YueWu1
My pleasure. As long as your feature layers are all come from the same feature service url, for example: Sync/WildfireSync (FeatureServer)
In this feature service, there are three feature layers, and you can use REST to create Replica and the download offline geodatabase can be use in offline mode as long as you setup all three layers to be downloaded.
