Getting hands on with latest ArcGIS Python API.Getting below error after running processing sample.
Using Geoprocessing tools | ArcGIS for Developers
from arcgis.gis import GIS
gis = GIS()
map = gis.map()
map
diegogarcia = gis.tools.geocoder.find_best_match("Diego Garcia")
map.center = diegogarcia
AttributeError Traceback (most recent call last)<ipython-input-3-cb8f9185cd0a> in <module>()----> 1 diegogarcia = gis.tools.geocoder.find_best_match("Diego Garcia") 2 map.center = diegogarciaAttributeError: 'GIS' object has no attribute 'tools'
I have completed all necessary configurations suggested at Install and set up | ArcGIS for Developers
conda,Jupyter Notebook and upgraded to latest versions.
Its exactly as the error says, there is no attribute or method with the GIS object for Tools.
arcgis.gis module — arcgis 1.0.1 documentation
You should look at the geocoding module.
I have tried geocoding module and it is working fine.
Should I infer that the example provided by ESRI at Using Geoprocessing tools | ArcGIS for Developers is wrong and get corrected in future ?
The code isn't wrong, per se, it just isn't accurate for the current version of the API. The structure of the API has changed fairly significantly over the past 6 months or so. Unfortunately, Esri has an issue with their URLs for the ArcGIS API for Python. For example, the 2 URLs goto different pages with different examples:
https://developers.arcgis.com/python/sample-notebooks/Using-Geoprocessing-tools/
https://developers.arcgis.com/python/sample-notebooks/using-geoprocessing-tools/
Notice the capitalization differences. The URL that is all lowercase has the most current/accurate content.
I just heard back from the ArcGIS API for Python team, the problems URLs have been updated to redirect to the current/accurate URLs.
