Using Arcmap with apache drill : Doesnt add drill views to Arcmap
1252
03-29-2017 10:34 AM
AshishAmbavane
Hello ,
We have apache drill installed in our MapR cluster and we wanted to connect it to ArcMap to add drill views via ODBC database connection.
We used MapR Drill ODBC driver (32 bit ) and connected apache drill to arcCatalog and arcmap. We are able to see the list of the views under the established database connection , but whenever we try to add view using add data to arcmap we get
 following error
" Could not add specified data object to map "
General function failure
If you can provide some inputs on this it would be of great help.
Ashish
JoeCline
Did you ever get ArcMap/Catalog to work with Apache Drill? If so, can you explain how you did it? Thanks.
