Attribute Assistant: Can you get a max area intersecting feature's value?
516
04-05-2017 11:40 AM
by Anonymous User
Not applicable
I have:
1.Land use/land cover (LULC) layer of polyogns (has field of LULC type like Cropland, Insitutional, Etc.)
2. Best management practice (BMP) layer of polygons
Situation:
The BMP layer has a Pre-LULC field to show the before land use and a Post-BMP-LULC field to show the after land use.  The Pre-LULC field is for one main value of the max area's intersecting LULC code within the BMP layer record's polygon.
Solution Trying to Find:
I use the attribute assistant heavily.  I currently set the BMP layer's Pre-LULC field to prompt the user to pick a LULC code to represent the field.  I would rather have the Pre-LULC field auto-populate with the LULC polygon that intersects the BMP Polygon the most, the max.  Just like when I do a dissovle and I have something dissolve on the max statistic.
Is this possible?  I do not see anything where you can do something like an Intersecting Statistics and get a concat of all the LULC values it intersected but get them something like LULC.Area?  Then, I can filter the max one or something along those lines?
by Anonymous User
Not applicable
Alternatively, I can create a prompt for the user to pick from all the intersecting land use's.  However, there is a domain on the land use code field on both files and it prompts the user a choice of codes to pick from that don't mean anything to the user?  Is there a way for it to prompt the field's domain descriptions instead of the values?
