Address Locator error on Online Geocode service
2533
7
04-04-2017 09:44 PM
MuhammadAfzal
I am using my owned prepared locator Geocode service (http://maps.dhalahore.org/ArcGIS/rest/services/DHAMAP/AddressLocator/GeocodeServer) in Geocode online (arcgis-appstudio-samples-master).
Working perfect on Reverse Geocoding but giving Error (Unable to complete operation. No Address Found) when i search any address in search box.
Here code:
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtQuick.Dialogs 1.2
import QtPositioning 5.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import ArcGIS.AppFramework.Runtime 1.0
import ArcGIS.AppFramework.Runtime.Controls 1.0
App {
    width: 800
    height: 532
    property double scaleFactor: AppFramework.displayScaleFactor
    property string errorMsg
    Map {
        anchors.fill: parent
        extent: usExtent
        focus: true
        ArcGISTiledMapServiceLayer {
            url: "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
        SimpleMarkerSymbol {
            color: "red"
            style: Enums.SimpleMarkerSymbolStyleCross
            color: "blue"
            style: Enums.SimpleMarkerSymbolStyleDiamond
        GraphicsLayer {
        GraphicsLayer {
        Graphic {
            symbol: simpleMarkerSymbolReverseLocation
        Graphic {
            symbol: simpleMarkerSymbolLocation
        Envelope {
            xMax: -15000000
            yMax: 2000000
            xMin: -7000000
            yMin: 8000000
            spatialReference: mainMap.spatialReference
        onMouseClicked: {
            graphicsLayerReverse.removeAllGraphics();
            var graphic1 = locationGraphicReverse.clone();
            graphic1.geometry = mouse.mapPoint;
            graphicsLayerReverse.addGraphic(graphic1);
            locator.reverseGeocode(mouse.mapPoint, 500, mainMap.spatialReference);
    ServiceLocator {
        url: "http://maps.dhalahore.org/ArcGIS/rest/services/DHAMAP/AddressLocator/GeocodeServer"
        onFindStatusChanged: {
            if (findStatus === Enums.FindStatusCompleted) {
                progressBar.visible = false;
                if (findResults.length < 1) {
                    showError("No address Found");
                } else {
                    for (var i = 0; i < findResults.length; i++) {
                        var result = findResults;
                        var graphic = locationGraphicGeocode.clone()
                        graphic.geometry = result.location;
                        graphicsLayerGeocode.addGraphic(graphic);
                    mainMap.zoomTo(graphic.geometry);
            } else if (findStatus === Enums.FindStatusErrored) {
                showError(findError.message + "\nNo Address Found");
        onReverseGeocodeStatusChanged: {
            if (reverseGeocodeStatus === Enums.ReverseGeocodeStatusCompleted) {
                searchBox.descriptionTextVisibility = true;
                searchBox.descriptionTextInput = "Address: "
                var address = reverseGeocodeResult.addressFields["Address"];
                var city = reverseGeocodeResult.addressFields["City"];
                var state = reverseGeocodeResult.addressFields["Region"];
                var zip = reverseGeocodeResult.addressFields["Postal"];
                searchBox.descriptionTextInput += address + " " + city + ", " + state + " " + zip;
            } else if (reverseGeocodeStatus === Enums.ReverseGeocodeStatusErrored) {
                showError(reverseGeocodeError.message + "\nNo Address Found");
                searchBox.descriptionTextVisibility = false;
    LocatorFindParameters {
        text: searchBox.searchTextInput
        outSR: mainMap.spatialReference
        maxLocations: 1
        searchExtent: usExtent
        sourceCountry: "US"
         Search button / box
    SearchBox {
        anchors {
            left: parent.left
            top: parent.top
            margins: 20 * scaleFactor
        onSearch: {
            findTextParams.text = searchBox.searchTextInput
            graphicsLayerGeocode.removeAllGraphics();
            locator.find(findTextParams);
            progressBar.visible = true;
        onClear: {
            mainMap.extent = usExtent;
            mainMap.mapRotation = 0;
            searchBox.descriptionTextInput = "";
            searchBox.searchTextInput.focus = true;
            searchBox.searchTextInput = "";
        Keys.onReturnPressed: {
            Qt.inputMethod.hide();
    Row {
        anchors {
            horizontalCenter: parent.horizontalCenter
            bottom: mainMap.bottom
            bottomMargin: 5 * scaleFactor
        ProgressBar {
            indeterminate: true
            visible: false
    MessageDialog {
        title: "Error"
        icon: StandardIcon.Warning
        modality: Qt.WindowModal
        standardButtons: StandardButton.Ok
        text: errorMsg
    Rectangle {
        color: "transparent"
        border {
            width: 0.5 * scaleFactor
            color: "black"
    function showError(errorString) {
        errorMsg = errorString;
        messageDialog.visible = true;
Any Info would be greatly appreciated.
Cheers,
"Tasadduq Hussain"
nakulmanocha
Hi there,
There are couple of issues here, directly related to your Geocoding service.
1) Your geocoding service is based on server 10.0 and hence only supports FindAddressCandidates. Therefore you should be using
 locator.geocode() method to perform Geocoding. This method calls the FindAddressCandidates operation
2) Based on your service address field. It currently takes Single Address labelled as "SingleKey". Hence you should only use that as your Address field parameter.
I have added these suggestions in your code and pasted below for your reference.
I hope this helps.
Thank you.
Nakul
App
    width: 800
    height: 532
    Map {
        extent: usExtent
        focus: true
            color: "red"
            color: "blue"
        GraphicsLayer {
        GraphicsLayer {
        Graphic {
        Graphic {
        Envelope {
            xMax:  8380686
            yMax: 3594113
            xMin:  8180686
            yMin: 3794113
        onMouseClicked: {
    ServiceLocator {
        onGeocodeStatusChanged: {
            console.log("geocode address found")
            if(geocodeStatus === Enums.GeocodeStatusCompleted){
                if(geocodeResults.length < 1){
                else {
                    for (var i = 0; i < geocodeResults.length; i++) {
                        var result = geocodeResults[i];
            }else if (geocodeStatus === Enums.GeocodeStatusErrored) {
                showError(geocodeError.message + "\n No Address Found");
                var address = reverseGeocodeResult.addressFields["SingleKey"];
         Search button / box
    SearchBox {
        anchors {
            left: parent.left
            top: parent.top
        onSearch: {
            var add = {"SingleKey": searchBox.searchTextInput}
            locator.geocode(add,"*",mainMap.spatialReference)
        onClear: {
    Row {
        anchors {
        ProgressBar {
            indeterminate: true
            visible: false
    MessageDialog {
        title: "Error"
        text: errorMsg
    Rectangle {
        border {
            color: "black"
nakulmanocha
Hi there,
I hope this helps.
Thank you.
Nakul
App
    width: 800
    height: 532
    Map {
        extent: usExtent
        focus: true
            color: "red"
            color: "blue"
        GraphicsLayer {
        GraphicsLayer {
        Graphic {
        Graphic {
        Envelope {
            xMax:  8380686
            yMax: 3594113
            xMin:  8180686
            yMin: 3794113
        onMouseClicked: {
    ServiceLocator {
                else {
         Search button / box
    SearchBox {
        anchors {
            left: parent.left
            top: parent.top
        onSearch: {
        onClear: {
    Row {
        anchors {
        ProgressBar {
            indeterminate: true
            visible: false
    MessageDialog {
        title: "Error"
        text: errorMsg
    Rectangle {
        border {
            color: "black"
MuhammadAfzal
I am very Grateful Nakul Manocha.
It's working perfect.
One question please "On performing search it's find all  addresses (E.g When I search 5 G 82 ,it's highlight 5 G 82,5 G 8/2 and 5 J 82) but I need when i write specific address it's only find that particular address.
It would be greatly appreciated.
Cheers,
"Tasadduq Hussain"
nakulmanocha
If you want only one address then you check for the score condition within the results and don't include if the score is not 100. I see based on your Geocode service I am getting lots of results with score >90. Hence I would recommend (
result.score <100) then it will include only one record.
http://maps.dhalahore.org/ArcGIS/rest/services/DHAMAP/AddressLocator/GeocodeServer/findAddressCandid...
else {
                        if (result.score <100)
                            return;
Hope this helps,
Nakul
AbdulMannan
It's great idea.
 I will putt condition on my matching score based on my Geocode Service.
I will replay you after putting condition..
Again I am very thankful to you.
Cheers,
"Tasadduq Hussain"
AbdulMannan
Very Grateful Nakul Manocha.
 I  putt condition
return;
I working perfect and find only one address but it does not Zoom to that particular address.
Please see the screen shot.
Highlight Adress But does not Zoom
Cheers,
 "Tasadduq Hussain"
nakulmanocha
That is expected as the single point geometry doesn't have an extent ( as min x,y and max x,y has same values). What you would have to do is to create a virtual extent around the point geometry and then zoom to that extent.
Another way is to create a buffer geometry (invisible- don't add it as graphic) around that point and then zoom to that buffer geometry.
Nakul
AbdulMannan
I create Locator with Minimum Match/Candidate Score 100.
Now,it's working perfect and find only one address and also Zoom to that particular address.
 Cheers,
"Tasadduq Hussain"
