Add AGOL Service to Portal for AcrGIS - Store the credentials
3283
16
04-05-2017 06:34 AM
GISMountains
New Contributor III
Hi all
I would like to add a 3D-Service which i published to ArcGIS Online in Portal for ArcGIS. Because it is not a public service i need to input the credentials.
If I insert it to a webmap I need to input the credentials every time? Is there a way to store them in Portal for ArcGIS?
Cheers
JakeSkinner
Esri Esteemed Contributor
What version of Portal for ArcGIS are you using?  I believe this was a bug at 10.2.2 where it would not prompt you to store credentials for secure services.
GISMountains
New Contributor III
Thanks for the fast response. We use 10.5 just installed 4 weeks ago....
JakeSkinner
Try adding the following service and see if it prompts you to store the credentials:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/FeatureServer/0
Username: user1
Password: user1
GISMountains
New Contributor III
I need to set the credentials every time i open the map
Is this still necessary with 10.5:
https://community.esri.com/thread/174629
JakeSkinner
You should receive the following:
Is there a reverse/forward proxy in your configuration?  If so, try setting this in the Portal Administrator:
Use a reverse proxy server with Portal for ArcGIS—Portal for ArcGIS (10.5) | ArcGIS Enterprise
Using a forward proxy server with Portal for ArcGIS—Portal for ArcGIS (10.5) | ArcGIS Enterprise
GISMountains
New Contributor III
Thank you for the response. Yes we have a reverseproxy in our system. We test this.... but not at the moment. I let you know if this was the problem.
GISMountains
New Contributor III
Hi Jake
Thanks again for the response. We are one step further. We configured the forwardproxy with the result to get the bullets to store the credentials.
But set to store the credentials or do not store the credentials and "add item" we get the following error-msg:
"Invalid service credentials A JSONObject text must begin with '{' at character 1 of "
What could cause this error?
Cheers
JakeSkinner
Do you receive the same error when you try with the service I provided previously?
Username: user1
Password: user1
GISMountains
New Contributor III
Hello Jake
Yes. The same error.
Cheers
