My subset wont work with image classification feature. All dropdown choices are grayed out. ?
762
6
04-07-2017 10:27 AM
CherithMerson
New Contributor III
Can't use image classification with my subset.  All choices in the dropdown menu are grayed out.
DanPatterson_Retired
you seem to be listing the non-selectable layer? does anything change when you select something else.
CherithMerson
New Contributor III
No, nothing changes.  It is calling everything I have in this file "not selectable", including he Landsat image files I loaded, the composite from those image files and the subset from the composite are all "not selectable".  If I select the composite, still nothing changes:
New "selection"
Customize, Extensions... is the Spatial Analyst toggled on?
CherithMerson
New Contributor III
No, I don't see any indication that Spatial Analyst is on...no check marks under Customize:  Extensions or Toolboxes.
I just added an image, showing that the classification methods are available only when the Spatial Analyst is toggled on
CherithMerson
New Contributor III
Oh!  Yes, a couple of assignments ago the Prof said to turn on Spatial Analyst!!  Didn't think that still applied.  Turned it on and:  Wa La!  Great!  Thank you, thank you!
