Share widget in JavaScript 3.x web app
1085
04-09-2017 02:17 PM
AndreiLuca
Is it possible to integrate a Share widget in a JavaScript 3.20 web app?
There is no such reference or sample code in the ArcGIS API for JavaScript website.
I found a web app that uses this Share widget but not sure where to go from here in order to integrate it in a web app.
Thank you,
Andrei
RobertScheitlin__GISP
Andrei,
   You would need to go get the source code from the Public Information template and strip out the share widget portion. There is not going to be a sample or tutorial for this.
GitHub - Esri/public-information-map-template-js: An ArcGIS Online mapping template to showcase soci...
AndreiLuca
Thank you Robert, the web app source code is a good start.
ESRI not having a sample or tutorial for a widget sharing ESRI products might sound a little strange
MathewSuran
New Contributor III
Have you had any success with this AndreiLuca2‌?
AndreiLuca
Hi Mathew Suran
No, just learning to code and this is above my skills for now.
