3D Surface from raster: ugly seam in texture / rendering help
1146
04-10-2017 06:10 AM
SimonBaril-Tessier
Hi, I am relatively new to ArcGis world,
I am trying to reprensent a DEM in 3D using ArcScene, and I want to animate it! I want a smooth surface, so I set the resample to "Bilinear Interpolation" under the display, but whenever I display it, I got theses ugly seams (see attached file).
I fixed the issue using the layer from data connection. But since I want to animate it (move the camera around the DEM) I cannot use "Render layer directly from data connection to conserve memory" under rendering tab (when the camera move, the display does not sync.)
So, in ArcScene, is there a way to achieve what I want or am I stuck with the seam when animating ?
Thank you very much,
Simon
DanPatterson_Retired
what seam?  looks fine
SimonBaril-Tessier
What do you mean ? Don't you see the joint? Here is another example !
