hgt
980
04-10-2017 02:01 AM
mohamedfelkir
bonjour
comment ouvrir les fichiers .hgt
merci
DanPatterson_Retired
from ...here...
HGT
Raw SRTM height files containing elevation measured in meters above sea level, in a geographic projection (latitude and longitude array), with voids indicated using -32768.
Single file—extension *.hgt
Read-only
16-bit signed integer
No
Unknown
mohamedfelkir
merci, Dan
il s'ouvre avec arcmap?
It has been too long since I have use that data source.  If memory serves Ascii to Raster but you need a header file if one is not present
mohamedfelkir
thank you very match
