Extract lines layer from OD Cost Matrix using model builder
2112
6
04-11-2017 02:27 PM
Jim_Gay
New Contributor III
I've created a model using model builder for an OD Cost Matrix and it's working quite well.  The part I am struggling with is getting the lines layer out of the network analysis data that is created using the model builder framework.  Below is the last portion of my model and I need to know what tools I can use to finish the job (take the line layers table and turn that into a permanent feature class and/or write to a geodatabase.  It should be simple but I just can't figure out which modules to use.  Any help would be greatly appreciated.  Thanks!
MelindaMorang
There is a special Model Builder utility called Select Data, and that's what you should do to extract one of the sublayers from an NA layer.  In ArcMap, you can find Select Data in the Insert menu -> Model Only Tools.  In Pro, it's under Utilities on the ModelBuilder tab.
MelindaMorang
AbdullahAnter
Occasional Contributor III
I agree with Melinda Morang Employee  , but I think it should followed by Copy Feature tool Copy Features—Help | ArcGIS Desktop  for saving in a permanent feature class. as Jim Gay want :
Jim_Gay
New Contributor III
Thanks!!! I looked all over for the select data module and could not find it. As the other person stated i will need to send this to a geodatabase so is there a certain tool I should use for that? Im guessing there are a few that would get the job done.
Thanks again!!!
AbdullahAnter
You can use Copy Features—Help | ArcGIS Desktop or Feature Class to Feature Class—Help | ArcGIS Desktop  after select data tool.
read that in my post:
Jim_Gay
New Contributor III
Thanks!!!  Great and accurate advice!
Jim_Gay
New Contributor III
One additional question has come up with my model.  It's working great (thanks again) but I need to iterate through the origins as they can range from 5,000 to 60,000.  I know there are iterators I can add to model so I am trying to figure out which one.  I have a feature class called Origin_FC that I can iterate through, should I use Feature Selection or Feature Classes iterator?
One more question, is it possible to find the drive time and drive distance using one OD Cost Matrix?  In this model I am going through with two matrices, one to find the distance and one to find the time.
Thanks!  If it makes sense to start a new thread, I can do that.
