Flow direction values of 1 - 255. Why is this happening?
1499
04-12-2017 07:20 PM
AnanG
I am using a practice data set to practice the delineation of watersheds. I have been following the manual and so far everything is going well. However, when using the "Flow Direction" tool, the output has values ranging from 1 to 255.
The values show that they extend from 1 to 255 but they go on to expand even more until 254Although it shows the value between 1 - 255, should I be worried? Why is it showing so many values?
Tags (1)
DanPatterson_Retired
That is what would be expected... see How flowdirection works
JayantaPoddar
MVP Esteemed Contributor
Adding to Dan, There are eight valid values of flow direction (1,2,4,8,16,32,64,128) depending on the direction a water can flow from a particular pixel.
Direction Code
If a cell's (or spatially connected cells') flow direction cannot be assigned one of these eight values in a flow direction raster, it becomes a Sink.
Think Location
