Hello all. I am trying to put together a Cascade style story map with the goal of having a webmap with multiple points of interest, or multi-view. While in the Cascade Builder, I have added a new Immersive section, navigated to my webmap, and begin to set it up.
I add new views with the Duplicate button to get the same webmap. However, when I alter the extent of the map in this second view/frame, it alters the extent of the map from the previous view/frame (and all others if there are more than two view/frames). Interestingly enough, the side text box "Continue your story here" does change and cascade properly with the new view/frame.
I have followed the process step-by-step and am sure it should be working properly as in the demo/instructions: https://nation.maps.arcgis.com/apps/Cascade/index.html?appid=a644a02894d246b59ecad16fae25b767 and https://nation.maps.arcgis.com/apps/Cascade/index.html?appid=a644a02894d246b59ecad16fae25b767
Any help would be greatly appreciated.
Thank you!
Solved! Go to Solution.
I figured it out. I was making my extent changes without having the Edit pencil selected.
