Time extent not publishing
892
04-19-2017 01:31 AM
subinks
I am trying to publish a time enabled mosaic dataset layer on ArcGIS server 10.5. I have  checked the option "Data changes frequently so calculate time extent accordingly' because my data changing on a daily basis. While publishing the time extent for the currently available data not publishing to the server. And when i am adding to the portal the layer is not identified as a time aware layer. I have used the same method for publishing the layers on 10.3.1 server and it is working also.
Anyone please help me through this.
AliBarakat
Occasional Contributor II
Adding Derek,
I guess he is the right person that can help you in this.
dlaw-esristaff
DerekLaw
Esri Esteemed Contributor
All,
Apologies for the late reply, I have been on business travel the last 2 weeks.
Unfortunately, I don't have much experience working with mosaic datasets. I suggest you re-post your question in this forum,
https://community.esri.com/community/gis/imagery-and-remote-sensing
Hope this helps,
