Select roof part with a angle <45%
1028
04-19-2017 04:25 PM
PeterVersteeg
Occasional Contributor II
Good day,
i have the same problem as: https://community.esri.com/message/395796?commentID=395796#comment-395796?q=dormer
i did try the 3  solutions but non seem to work anymore.
the rule work becouse the gable roof angle is >45% but if i set it to <45% it fails.
I like this approach (word.north, etc) because I can use lidar data to search for the domers and then fill a field on what location on the roof they are.
@StartRule
Lot -->
extrude(20)
comp (f) {front: Front | side:Wall | top:Roof}
Front -->
color (1,0,0)
Wall -->
color (0,1,0)
Roof-->
roofGable(50)
comp(f) {world.north : Roofdormer | world.west : Wall |world.east : Wall | world.south : roof }
Roofdormer-->
color (0,0,1)
split(x){'0.40 : roof | '0.2 : DormerLocation | '0.40: roof}
DormerLocation-->
split(y){'0.4: roof | '0.3 :Dormer| '0.5: roof}
roof-->
color (1,0,0)
PeterVersteeg
Ok  with help from Niels vd Vaart from Esri the Netherland I have a solution.
I am using the geometry.angle(azimuth) to get the azimuth of the roof and so get the side I want. This only works when my house is facing the right angle for my rule. I have to think how I can make this work for houses with all angles. But for now this is what I got:
@Range(1, 89)
attr GableAngle                   = 50
@StartRule
Lot -->
extrude(10)
Front -->
color (1,0,0)
Wall -->
color (0,1,0)
Roof-->
roofGable(GableAngle) GableRoof
GableRoof -->
       case GableAngle < 45 : RoofGableA
       case GableAngle > 45 : RoofGableB
       else :NIL
RoofGableB -->
       comp(f) {front : color(1,0,0) frontA. | back: color(0,0,1) backA.}
RoofGableA -->
       comp(f) {top : color(1,0,0) frontB | bottom: color(0,0,1) backB.}
frontB-->
#      comp(f) { all : color(0.5, geometry.angle(azimuth) / 360, 0.5) Shape. }
       case geometry.angle(azimuth) < 90 : color(0,1,0) Nside
       case geometry.angle(azimuth) > 90 : color(0,0,1) Sside
       else : NIL
Sside-->
       split(x){'0.40 : NoDormers | '0.2 : DormerLocation | '0.40: NoDormers}
DormerLocation-->
       split(y){'0.4: NoDormers | '0.3 :Dormer| '0.5: NoDormers}
Dormer -->
       color(1,0,0)
PeterVersteeg
@Range(1, 89)
@StartRule
Lot -->
extrude(10)
Front -->
color (1,0,0)
Wall -->
color (0,1,0)
Roof-->
GableRoof -->
       else :NIL
RoofGableB -->
RoofGableA -->
frontB-->
       else : NIL
Sside-->
DormerLocation-->
Dormer -->
       color(1,0,0)
