"Failed to save raster dataset"
7945
9
04-22-2017 09:21 AM
SHAHIDRAZA1
curtvprice
MVP Esteemed Contributor
There are lots of reasons this could happen -- invalid pathname, not enough space on disk ...
The screen shot seems to suggest that you are trying to georeference a raster and that your control points are producing a very inadequate (high-error) transformation. The image looks terribly distorted.
SHAHIDRAZA1
Thanks Curtis, i will retry with more adequate control points,
i appreciate your help...
Regards,
Shahid Raza
DanPatterson_Retired
make sure they are spread about the image... if your control points are closely clustered, there is no way that you will ever get an acceptable result.
SHAHIDRAZA1
Ok, I will keep it in Mind, Thanks Dan...
Best Regards,
Shahid Raza
Shauna-RaeBrown
I've had the same non-descriptive error message.  If you try to name your raster starting with a number, you'll also get his error.  For example, I first tried naming a raster that I georeferenced 2019-01-08_AreaName.  Then I tried again with AreaName20190108, and it's rectifying as expected.  I hope this helps.
do note that  AreaName20190108 wouldn't work if the output raster was an esri grid since the name is too long, but it would work for a *.tif
LeonardoBarua
A quick and dirty solution is to do an export>export data from the table of contents. The exported GeoTiff will retain the transformations you inputted with the georeferencing tools.
peterEngeneere
HOW can i rectify it now???/
yys
I had the same problem as you, and I rebuilt the pyramid. 我遇到了和你一样的问题,重新建造了金字塔就可以了。
