Where can I change GP Task URLs inside app folder generated by WAB?
1720
14
04-21-2017 08:26 AM
FrancescoTonini2
Occasional Contributor II
I am trying to unzip and deploy a web app created with WAB 2.x. onto a different PC. However, I would like to update the Task URL of all my GP widgets to re-route them to a different GIS Server I am using now. Which file(s) should I look at inside my ../webappbuilder/server/apps/<app_number> folder to modify and update the new task URLs and leave everything else untouched on the app structure?
RobertScheitlin__GISP
Francesco,
   That would be the apps configs/Geoprocessing/config_Geoprocessing.json
Francesco,
FrancescoTonini2
Thanks a lot Robert! Should I just change URL in the "taskUrl" key or also in "helpUrl" and "serverInfo"? Meaning the fist part http://<domain or IP address>/arcgis/rest/ etc. of all the 3 parameters?
All 3
FrancescoTonini2
Robert,
I have updated all 3 as you said, but now when I try to upload an input file (GPDataFile) to one of my GP widgets, to which I changed the task URL, I get the error below:
"Failed to execute 'open' on 'XMLHttpRequest': Invalid URL
Do you think this could be caused by the change of task URL? I never got this message when uploading my table before doing the change...
Correct, That sounds like you have made a mistake in the url.
FrancescoTonini2
There must be something else going on then, I double-checked all URLs (the 3 above) and they point correctly to the REST end point of the GP services on my new GIS server. I can of course also try to open a ticket with ESRI if you don't know what other reason that error could be caused by. Just wondering.
So if you enter the url in your browsers address bar it reaches the rest endpoint without issue right?
FrancescoTonini2
Correct...
And the task url has the GPServer/...sometask right?
